Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Dimension Not editng?
1 REPLY 1
athurD
333 Views, 1 Reply
athurD
Hi all.
I have a prolem, When I see movie trailer about advance concrete 2015 I see dimension on video have edit change,But Why I creating  dimension with my project have'nt change and edit, Why? and how I can do that with same picture. I don't want explorer dimension. thanks
Hi all.
1 REPLY 1
in reply to: athurD
If you are using the parametric dimensioning you cannot edit the text unless you explode, which is time consuming.  If I have a dimension i want to add text to i ensure my "dimlfac" is set to the proper scale and use the basic autocad dimensions.  If you're using basic autocad dimensions be careful that your detail is not clipped because the dimension will be wrong.
