Diagonal Beam specific model role name
  • Hi.. I would like to know what we call a diagonal beam when it comes to model roles. This diagonal beam is not bracing. The top part of this is beam is connected to the web of a column through an end plate and the bottom part is joined to a horizontal beam through a miter cut.
ArjunGaba
@Anonymous  if it is not a brace Than it will have same model role as you are using for other beams..
