Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
DetObjQualifierFilter (Pre-Defined Remark)
5 REPLIES 5
Flies-Eyes
331 Views, 5 Replies
Flies-Eyes
I use the Pre-Defined Remark parameters to allocate different values to objects. I have previously created new Model Object filters to assist with assigning labels.
I have trying to a write the script that createsthat filter, although I am not having luck.  I saw in a video that Pre-Defined Remarks had some pre loaded values, 'Denotation1' 'Denotation2' etc however I am thinking this parameter class must go by a different name and not 'Denotation'.
Here is my attempt that doesn't work:-
Function checkElement(Obj)
bValid = False
' Check if the Denotation property is 'Welded Assembly'
If Obj.Denotation = "Welded Assembly" Then
bValid = True
checkElement = bValid
End Function
I have looked in the Advance Steel COM API Reference Guide to see if I could figure it out but I have no joy as yet so seeking help with this.
Are the eAttributeCodes where I should be looking?
As a side note, in the .XSLT videos they used the Pre-Defined Remark parameter and they seem to call it 'annotation' in their .XSLT script which didn't make sense to me.
bValid = False
bValid = True
End Function
5 REPLIES 5
Flies-Eyes
in reply to: Flies-Eyes
Flies-Eyes
This is what the BOM editor is telling me, this could explain the 'Annotation' class in the .XSLT video.
Is this telling me that the Pre-Defined Remark object class is called 'Annotation'?
Flies-Eyes
Flies-Eyes
I tried this script but still no joy.
bValid = False
' Check if the Pre-Defined Remark property is 'Welded Assembly'
If Obj.Annotation = "Welded Assembly" Then
bValid = True
End Function
bValid = False
bValid = True
End Function
Flies-Eyes
Flies-Eyes
This is what I found in the .XSLT video.
"singlepart [(part/annotaton = 'Denotation1')]"
I am not sure what this is trying to tell me.
Flies-Eyes
Flies-Eyes
After further testing overnight, I have come to the conclusion the correct class is Obj.Note.
Flies-Eyes
Flies-Eyes
The result....
The result....
