Dear Expert,
Detail frame layer only show the move to near cursor.
How to permanently show that layers?
Solved by Rob_Merriman. Go to Solution.
There is a management setting that controls the detail frame visibility, see screenshot below. Tick the default, reload the settings and it will always show. You will probably have to close and reopen any drawings you have currently open.
Rob Merriman, AEC Technical Lead, Graitec
Dear Expert,
Thanks for your valuable reply.
Here, two box shown, but only one box highlighted.
How to visible another box?
So the outer green box is the Detail frame, this is what is controlled by the management setting so it will always be visible. The inner green box is the view frame, there isnt a management default to keep this on automatically im afraid.
The detail can be made up on many individual views as shown on the assembly detail below
There is a button on the ribbon to turn these view frames off but nothing to keep them on all the time that I am aware of
