Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Cut Section View
1 REPLY 1
bageseabraham
324 Views, 1 Reply
Cut Section View
Is it possible to do the section cut view in angle?
I know that we can do a cut section at any angle, but I need the detail view in the same orientation.
Abraham
1 REPLY 1
in reply to: bageseabraham
hHi,
You can't do that normally it only by 90 deg. but:
1: you can finish the view (put all label and cotations) and after move the view out of the layout.  (make a copy).
2: you explode the copy, select all object and rotate them at the angle you want .
3:  you plave it in the layout where you want it
THX
