Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Cut Down & Up Symbol
2 REPLIES 2
bageseabraham
474 Views, 2 Replies
With regards to cut symbols, whenever I am creating detailed drawings, this cut symbols comes on my side views. If I delete this one, it will pop up again after the update.
My question is, how do I or is it possible to get rid of these symbols? Also, how can I change these symbols to a different style?
All advice will be greatly appreciated.
Best Regards
Abraham
2 REPLIES 2
in reply to: bageseabraham
You can find the cut symbols in your symbols library ( c:\ProgramData\Autodesk\Advance Steel (yourversion)\Shared\Support\Symbol ) best to copy to a new name in the same folder and then modify the existing (cutsymbolup.dwg and cutsymboldown.dwg) to your preference keeping the attributes intact.
Then open management tools in AS then in the defaults tab you want to open Drawings - Labelling - General and then use your new symbols.
Click on load settings in AS and then update defaults on the main screen to the right of the management tools icon. The program may need to be closed and then reopened for this to work.
If you don't want to use the up or down symbol then when you create your up or down symbol drawing delete everything in it and then save and use in the management tools as the up or down symbol.
Gary
bageseabraham
Thanks Gary.
Much appreciated.
