Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Custom hand rail posts
7 REPLIES 7
Message 1 of 8
854 Views, 7 Replies
I need to be able to create hand railing with 3" flat stock that has radius cut into the top creating a semi-circle at the top of the post.  I see options that allow you to chamfer but none that allow you to add a radius.  Is this possible?
Thanks!
7 REPLIES 7
Message 2 of 8
markhubrich
What is your top rail material?
...and fix the kiss export issues.
Message 3 of 8
in reply to: markhubrich
Top rail material is 1-1/2" round pipe.
Message 4 of 8
muleman1
Not sure if we understand question, but is this similiar to you want?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 5 of 8
in reply to: muleman1
This is what I'm after.  The handrail will be short sections about 4'8" long that sit between 2 hanger rods. The top hand rail will not sit on top of the post but rather sits between the posts.
Message 6 of 8
muleman1
Message 7 of 8
I have it to the point that muleman1 shows but I can't figure out how to get the radius in the post.  I see that there are some cut planes shown, were those added after the railing command was run?
Message 8 of 8
muleman1
Yes. I would get all my posts correct. Then use the corner cut tool on one and then 'copy selection' to apply to each other post. There may be better way, we are FAR form expert. If there is better way maybe someone else will chime in.
