When you make Custom Connection, even if the direction is different when applying to other connections, it does not apply correctly. The connection you need to apply must be exactly the same. Is there a solution to this problem?
Solved by bigcarl5000kg. Go to Solution.
Unfortunately, for each new UCS you need a new custom connection version
