Hello, I am having some difficulty figuring out how to make a certain custom connection using the Advance Tool Palette. I was able to create the connection below. However I need to create one that is essentially the same however the horizontal HSS is turn 90 degrees. so it clips in the middle of the beam and not the end.
So far, this is the closest I have been able to come. I need the top clip to be turned to mirror the bottom clip.
If anyone has any suggestions I would greatly appreciate it. Thanks
Link copied
