CROSS BRACING TUBE CONNECTION PLATE
hEINSTEIN
Message 1 of 9
hEINSTEIN
Hi, I have cross bracing that;s made from CHS. Is there a macro that I'm missing to add  a bracing plate cross or do I need to make a custom connection.
If someone could please show me in some sort off direction that could help me.
I have attached a screen shot of my model, and a picture of the sort of connection I want to add.
Thank you in advance.
Replies (8)
Message 2 of 9
acbsdesign
This would be Four Diagonals Middle Gusset Plate:
Have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 3 of 9
hEINSTEIN
Hi
Thanks for the suggestion, but this connection is for angles.
I want to use circular hollow sections, which changes the connection because it needs a sandwich plate (this is what it’s called in AS tube connections). And I also don’t see a four diagonals gusset plate under the tube connections.
I made a quick 3D model of what the connection should look like in attached picture.
Message 4 of 9
acbsdesign
Ok, I see,
Below is a screenshot of two connections combined:
I will attach also the dwg, all can be combined in a custom connection if this is repetitive.
Message 5 of 9
acbsdesign
I need a vacation. I don’t have the closure plates included.
Message 6 of 9
hEINSTEIN
Hi @acbsdesign
Thank you for the effort, much appreciated.
I'm working in version 2019, will you be able to save it to 2019 for me to open?
Message 7 of 9
acbsdesign
No, you will need AS2020 to open the file.
Why don't you use AS2020-it is stable, with added functionality.
But anyway, it is a few minutes of work to make the connection.
Have a great day.
Message 8 of 9
rclement
DID YOU EVER GET A SOLUTION ?
CAUSE ON HERE I CANT GET TO IT
Message 9 of 9
I made this connection manually and added it as a custom connection.
I hope this helps you
