Creating Pipe Support Families that can then be exported to advance steel
sagnewYUXLR
Message 1 of 22
sagnewYUXLR
Hi there,
looking for some advice on a workflow between revit and advance steel..
we are modelling/designing in revit (pipe, pipe supports etc)
is there a way we can use the advance steel features in family creation so that we can then export it to advance steel? the only current way I can see to create the supports is either in family using extrusions, as the plate/bolt option isn't available when creating families, or create the support in the advance steel and export it over, however i am then unable to assemble this into one assembly or group.
example of support in revit
example of support in advance steel (which we want for our workshop etc)
i am just wondering what is the best workflow for this type of scenario.
many thanks
Replies (21)
Message 2 of 22
Flies-Eyes
My recommended workflow is to model in Advance Steel and push back into Revit as an Revit Assembly.
If you would like to share an Advance Steel model of the pipe support, I can show you the resultant workflow when I push it back into Revit.
Message 3 of 22
sagnewYUXLR
Thanks, but does revit allow me put things into assemblies like plates, bolts etc?
Message 4 of 22
sales7NF7D
Yes, if done correctly.  I saw this posted on a Facebook Forum.
Message 5 of 22
Flies-Eyes
Here is an example of a detailed Advance Steel model pushed to Revit with Assemblies/Bolts/Anchors/Concrete/Special Parts/Weld Preps/Galv Holes etc etc.
Message 6 of 22
vuongbui.nuce
never use revit for Steel, Never!
Message 7 of 22
sagnewYUXLR
why not? i could maybe understand why for complex structures but pipe supports etc?
also we receive many models from design houses which have been modelled in revit, not many will use other packages.
i think if autodesk enabled the advance steel import in the family creation and not just rvt it would be a huge bonus.
Message 8 of 22
sagnewYUXLR
that looks very interesting
i am running advance steel 2025 do you have a copy for me to send over a dwg file example?
Message 9 of 22
Flies-Eyes
If you have a AdS 2024 model file of an Assemby that you would like to see in Revit as an Assembly, I can test a conversion for you.
Don't forget to 'Store Data'.
Message 10 of 22
sagnewYUXLR
yeah, unfortunately i only have AS25 running now 😞
when i load an .smlx file in the parts come in as individual items that I cant then group or assemble?
is this something in advance steel i need to update before exporting to the smlx?
Message 11 of 22
Flies-Eyes
.smlx is version neutral so can go backwards with that file format.
In any case do you have any old models or assembles from 2023 or 2024?  It doesn't need to be anything big just something you will recognise and be able to check the Model Roles, Material, Profile Size, Coating, Assembly Numbers, Part Numbers etc when I push it into a Revit Assembly.
Message 12 of 22
sagnewYUXLR
not sure if this is of any use.
many thanks for this its much appreciated
Message 13 of 22
Flies-Eyes
I am just on my phone ATM... what does that file look like.?
Message 14 of 22
sagnewYUXLR
Message 15 of 22
Flies-Eyes
Perfect.
I will give that a crack tomorrow.
Message 16 of 22
Flies-Eyes
The original model file was missing some welds and model roles, so I have added some welds and model roles to the additional supports on the right to demonstrate the difference.
The pipe support with the shortest pipe is the original model file.
The pipe support in the middle has 'Shop Bolts' to create a combined welded and bolted assembly.
The pipe support with the longest pipe has welded assemblies and 'Site Bolts'.
I used my numbering system for the 2 pipe supports on the right, which also utilises Lot/Phase for numbering.
Advance Steel
Revit
BIM Data
I would be interested to see if you think this workflow to model in Advance Steel and pushing detailed models back into Revit is a viable solution.
Message 17 of 22
Flies-Eyes
Pipe Supports exported to Blender.
Message 18 of 22
sagnewYUXLR
thanks that's great, are you able to send over the advance steel file as well please for us to have a look at?
Message 19 of 22
Flies-Eyes
I have left the office for the day but maybe tomorrow.
I can't post it here unless I strip my template data out.
Message 20 of 22
sagnewYUXLR
ok thanks again for your help its much appreciated
do you use the smxl file to export back into revit or are you doing it using IFC files?
