Create Elevation View in model
Message 1 of 12
Dear All,
How to create any elevation view in the model by grid or line, and in this view can show Grid same as my picture below, when I active my view it is not show my grid and level?
Thanks All
Replies (11)
Message 2 of 12
HI,
Anyone please help me!
Message 3 of 12
FCort
Grid in elevation views no possible in model space. Just in drawings.
Message 4 of 12
HI,
When I want model 2D frame If I can not see my grid in elevation, how to modeling my structure in elevation view?
Message 5 of 12
chrisengg
you can use Project explorer for different grids and elevations if you want
Message 6 of 12
arkli2009
I believe "3D Grid Line" is the only reasonable solution of this. Let's all close our eyes and make a wish.
Message 7 of 12
FCort
Guys, the best way to be implemented is voting up for the idea .
https://forums.autodesk.com/t5/advance-steel-ideas/3d-grids/idi-p/7090434
Message 8 of 12
arkli2009
Everybody please go vote!!!
Message 9 of 12
AleckGiles
You can set your UCS vertical and draw a grid on a vertical plane. Then you will see this in the elevation view.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 10 of 12
HI sir, We dont want same Grid label in elevation view. We want to view Elevation level (El.+000) in Gridline elevation view in model space. Please refer snap. we want to see same as in Model space. Regards, Anwar
Message 11 of 12
shrinal_bhatt
Community Visitor
Community Visitor
Hi Anwar,
I couldn't find any command in Advance Steel showing Elevation level Grids likewise in E3D or S3D. Let me know if you have got any resolution to your question.
Thanks.
Message 12 of 12
willianSWEAV
Hello. You can create the grids vertically as indicated by @AleckGiles and name them according to their elevations. Create one grid for each elevation and edit the name of the gridwithin the grid properties, with the elevation information, so you will have what you desire. It's an alternative method, but it should work."
