Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Create custom icon
4 REPLIES 4
eyal.ch
249 Views, 4 Replies
Create custom icon
Hi Everyone,
I want to create a custom icon like the advance/trim extend, that when I click on it, it automatically chose the extend and the center, and gives me the possibility to proceed from there.
I want to shorten the clicks.
I think I should do it with the macro:
but I don't know what is the command of the
and how to make the command select the extend and center automatically.
thank you
4 REPLIES 4
pendean
in reply to: eyal.ch
bigcarl5000kg
Hi @eyal.ch,
use this macro in your (new) command:
C^C_AstM9CommTrimExtend;E;C;
E - for Extend
C - for Center
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
eyal.ch
in reply to: bigcarl5000kg
Thank you @bigcarl5000kg ,
It's exactly what I wanted.
Sebastian_Eiche
additional information
If you want to create a few more commands, have a look here:
https://forums.autodesk.com/t5/advance-steel-forum/advance-steel-custom-commands-share-your-ideas/td...
You will find a lot of very helpfull commands there and sometimes there're also pics.
for the commands
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
