- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
is this possible to make connection sheet with Advance steel like this?
Hi Everyone,
The Advance Steel Extensions for Revit 2019 and 2020 have been out since shortly after those versions of Revit (i.e. nearly a year for 2020). You have to log into your Autodesk account and look under Manage Products to find them.
Aleck Giles, Structures Consultant, Graitec
Hi, @AleckGiles
thank you for your reply but i can't found Advance Steel Extensions2019/2020 in my account where can i find it?
Look under the product updates, 2020 version is down as a hot fix
top left of the interface, then use the search, Advance or extension
John Bennett
try this image- just set to product updates and then in search 'Advance'
Hi, @Steel-User-GRTC-John-Bennett
thanks for your reply.
I found it with your pic it's really easy to understand thank you so much.
