Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Copy saddle cut to other tubes
6 REPLIES 6
spufut
402 Views, 6 Replies
Hi! I am trying to make a "saddle" cut between tubes and i used "Element contour"  command to create it. My question is, can i copy this cut to other tubes or should i use "Element contour" command every time?
Using "Element contour" is the best way to create saddle cut?
Thank you!
6 REPLIES 6
bigcarl5000kg
in reply to: spufut
You can still copy this via these tools:
Select the grey box of one existing saddle and apply it to another elements
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
spufut
in reply to: bigcarl5000kg
I thought about this, but the problem is that after i make the cut, there is no grey box like the one i have when i use Miter/Cut at object. I have only the green circles.
mick-CNF
in reply to: spufut
You can use propagate joint.
Select the joint box and right click.
It will add this to all visible items the same size and they will all be in a group so you only need to edit a master joint to make any changes.
Screenshot 2023-06-14 102221.jpgScreenshot 2023-06-14 102248.jpgScreenshot 2023-06-14 102341.jpgScreenshot 2023-06-14 102437.jpg
If this information solves your problem please accept as a solution.
bigcarl5000kg
in reply to: spufut
spufut
Thank you, it was my mistake. I used "Element contour, UCS", instead "Element contour, rule".
Rookie mistake 😄
bigcarl5000kg
in reply to: spufut
For propagate the joint, be carefully, it get all the same possible connections, even if you don't want one or more.
Check the possibility of all the tools here, you will be surprised:
