Hi! I am learning AS 2018.
I have prepared one face of structure, Now I want to copy all bracings and joints in other 3 sided. I tried with Mirror3D command but it gives bracings and bolts but no holes in the flange.
how to do it. can any one give me idea.
Avinash
Solved by adrian_ricinschi. Go to Solution.
in this case, you may find it easier to find the Center of the structure and use this as a point of polar array. Use the transform elements interface , set to polar copy, Center point, and set rotation to 90, the 3 no. You may have to select the corresponding leg, when applying.
John Bennett
I made a movie with the use of polar array in Advance steel.
But this option works only because your structure is rectangular.
