cope one side of flange
leroyspike
Message 1 of 9
leroyspike
Hope someone can help me with this as i can't seem to find a solution on google.
I am trying to cope the top flange on a UB but I only want one side to be copped. I can only seem to either cope the top & bottom flange or the entire top flange depending on what orientation the UCS is in. Is there a specific tool for this that i am missing?
Thanks in advance.
Replies (8)
Message 2 of 9
steeldesgn
You can set your ucs to the top flange and draw a polygon for your cut out and use the advance steel cut to poly line
Message 3 of 9
steeldesgn
I think I ment cut to polygon in the beam modification tool bar
Message 4 of 9
johnjmbennett
You use element contours , like rectangular, round etc, with the dialog is opitions to control the depth , these are activated via a check box, enter figures and these control the depth of the cut. The contour is placed relative to the system line and the xy plain of the UCS .
System line set to beam top, then UCS to top beam flange, use rectangular contour opition, drag/snap to size. The in properties select side for depth enter figure for depth.
In model there is Also a grip point for depth that can be adjusted.
size of cutout has grip points for selection and moving/resizing.
Similar thread over control of contour depth
https://forums.autodesk.com/t5/advance-steel-forum/recess-in-plate/td-p/7411403
John Bennett
Message 5 of 9
muleman1
see if this screencast is what will help...
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 6 of 9
leroyspike
Thanks all for the answers. got it sorted.
Message 7 of 9
irondogs2k
Community Visitor
Community Visitor
I have a similar issue; however I only want to trim the bottom flange.  I am an extreme AS beginner and am struggling to get a Shops set out.  I have to trim the bottom flange only on one side.  This direction you give works great, but it is trimming both the top & bottom flange.  Can you help figure out how to trim only the bottom flange?
Message 8 of 9
steeldesgn
Could you please add a screen shot of what you are trying to do so we can better understand the situation
Message 9 of 9
Albert.Maduro
Thank you for this
