Contour Slot Dimensions in Tube Brace
jgalvarez
jgalvarez
I created vertical Tube bracing using the Brace tool in the Extended Modeling Panel. I connected the tube brace at the ends using a Gusset Plate connection as shown below.
Vertical Brace connection.JPG.
My fab drawing will not auto dimension the contour slots at the ends of the tube brace. The Model Role is set to Vertical Bracing which uses the Drawing Style Tube Bracing. How can I change my drawing process/drawing style or model role to get these dimensions to show up?
Vertical Brace.JPG.
Juan
jgalvarez
The model role for these are vertical braces. I am using a drawing process to generate the shop drawings. I can manually enter the dimensions, but is there a way to make them automatically appear?
