connecting an ladder to handrail
Does anyone have any ideas on how to connect a exit left cage ladder to handrails?
I've attached an image for reference.
crydee-AG1
Obviously, the ladder and the rail are separate macros and will not automatically connect. You need to look at the "Exit > Brace Dimensions" page of the ladder joint properties. Play with the values of "11. Dimension 1" and "12. Dimension 2" to get the vertical plate aligned with the rail and then manually place the bolts between the plate and the rail.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
markhubrich
Another important thing to keep in mind with ladders is to keep an eye on the connection box. You know that frame you double click on to edit the ladder. If it turns red, it does not agree with something and changes to any value other than the one creating the error will not have an effect on the model. Nowadays I watch that box closely during each value adjustment. Especially on cages, it could be tough to find the culprit value if not caught straight away then it's usually less frustrating to start over.
...and fix the kiss export issues.
yes, I've noticed it turn red sometimes, I undo what I did right away or change it back.
thanks, that helps, didn't know I could widen the opening like that.
