Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Collision check volume unit change
2 REPLIES 2
Arnie.Smith
209 Views, 2 Replies
Can someone tell me how to change the collision check volume unit setting. Mine is set to m cubed and I want to be able to change it to mm cubed.
Regards
Arnie
2 REPLIES 2
Buxtehude1963
in reply to: Arnie.Smith
type the command "_AstM4CommProjectData", select "volume unit".
The ribbon button for this command is in "Start", "Setting" , near the button for "Management tools"
Arnie.Smith
in reply to: Buxtehude1963
Thanks. That worked
