Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Clash Checks - Do they work?
2 REPLIES 2
rigid_joint
324 Views, 2 Replies
I run the starting guide example and I do some tests.
I placed the bolts outside the plate/section flange and I run the "Clash Check". I get no clashes at all.
What's going wrong?
2 REPLIES 2
wtheron
in reply to: rigid_joint
I believe there is no clash reported as there is no colission volume of interfering solids for the software to recognize. You can modify the collision accuracy and volume from the Management tools.
In your example I believe the Steel Construction Technical Checking ( AstM5CommSemanticCheck ) from the extended modelling ribbon will give you better results.
rigid_joint
in reply to: wtheron
Thank you for your tip. It seems that this is the answer that I was looking for
Technology Administrators
