CJP Weld
chris_aguilar14
Observer
CJP Weld
chris_aguilar14
Observer
Observer
I need to do a cjp weld in the top flange only, is there any tutorial how to do it
thanks
bigcarl5000kg
Hi @chris_aguilar14 ,
post some example picture here for your weld type ... it refers to user weld or some weld in connection macro?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
acbsdesign
@chris_aguilar14
I will share a few details that are most-commonly used, showing both flanges:
1. Beam to Column, field welded, TC-U4a
2. Shop welded: TC-U4a-GF, the backing bar can stay, it is a prequalified weld, this is just for the latest project with the reinforcement.
3. These are flange to flange:
Hope these will work for you.
Basically, the first thing to consider is available position, thickness, and what is used as equipment if it is field or shop welded.
Look at AWS D1.1 ( or D1.5 if it is a bridge project). If you have HSS on one side, D1.5 does not cover HSS. So AWS D1.1 shall be used instead.
If you can output nc and beveling is done by nc, then use weld requiring beveling.
If you have an option for carbon stick to be used for U-groove, this may be the best option.
Hope this helps.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
chris_aguilar14
Observer
Observer
I need beam to beam CJP B-U4a, 1/4 root opening and 45 degrees see below
acbsdesign
@chris_aguilar14
I just saw the second post, it is B-U4a, (or GF), one side beam flange will have 45 degrees bevel, 1/4" gap, backing bar and 1" radius at ea beam.
chris_aguilar14
Observer
Observer
thanks for your reply, do you have a tutorial/video of how to accomplish the full pen weld in advance steel
