I have a circle folded plate saved as an 3D AutoCAD object (that exported from the Inventor).
I tried creating it by using Advance Steel (create folded plate function), but failed.
My final purpose is a flattened plate exported from the folded plate.
I have only been using Advance Steel for a few years and my English is not good.
I posted the AutoCAD file here, could some one please hepl me.
I really appreciate and thank you for your help.
Solved by bigcarl5000kg. Go to Solution.
can you use this object as special part in Advance Steel (will be produced according to the model / drawing from Inventor)?
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-E5CAFC93-D4E6-43BE-9C92-7A7292B489BB
If not, you have several options, with a rather complicated path to the result. However, do not expect the same quality of the result, this cannot be achieved in Advance Steel.
One of the possibilities:
If you can export a 2D sketch for this object from Inventor incl. bend lines (polylines or other flat objects), import it, create a 2D polyline from the contour (if it isn't already) and then simply use it as a base for the polygon plate :
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-BD7A737D-8EAE-4E5B-B621-1E5DEDF85443
Example:
2D polyline
Polygon Plate
For the bends, you need the bend lines (red color) - help them divide the sheet into the necessary segments (here separated by color) :
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-6AC68460-623C-4070-AA46-8980EF4948A7
Now create the bends (settings for angle and radius see inventor) in a logical sequence so that the bends can form :
https://www.youtube.com/watch?v=VoBM74YX4uI
https://www.youtube.com/watch?v=r7BEKmyAglc&themeRefresh=1
1. bend
2. bend
3. bend
4. bend
