I have a lot (>100) of connections of the same type (also have the same properties picked from library), and I would like to change them all to different type of connection. What is the most efficient way to do it?
Best regards
Robert
OK I realized that it might not be possible at all, because different type of connection requires picking new elements that should be connected in the order specific to each connection type.
So now I have a bit different question: Is it possible to change properties of several connections at once (I'm talking about connections which are not in the group)? For example I have 5 identical connections and I want to choose for them other properties from the library. When I select more than one connection box there is no common Advance Steel properties except updating it so It can't be done that way...
Best regards
Robert
John Bennett
FYI, it is now possible w/ Graitec PowerPack Joint Multi Edit
They do have to be one type of connection.
