Change stair alignment after creation?
When creating a stair using stair tool.  One of the choices is left, middle or right align.  If you choice right but after modifying you need it to be middle is there a way to change it or are you stuck to recreating?
CHRIS_ASDL
Firstly go into 2D Wireframe. You will then notice a structural element frame around the staircase. Simply drag the grips in the direction you want to go. You can then adjust the width of the stairs once its correct.
Hope that helps.
Kind Regards
Chris
