Change prototype
Change prototype
S.MANICKAVASAGAM
Message 1 of 11
Change prototype
S.MANICKAVASAGAM
Dear Expert,
                   In change prototype option, the advance steel prototype not in issue when changed.
               But, customized own prototype changed the prototype not display.
               How to get, please to be guided. prototype file attached.
                https://autode.sk/3vceHUz
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Replies (10)
Message 2 of 11
Sebastian_Eiche
Maybe the starting point is moved? which one is set in the layout settings?
also: you have no frame on your prototype, this is needed for knowing the limits of the layout
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
Message 3 of 11
ArjunGaba
@S.MANICKAVASAGAM  please use zoom extent command to find prototype objects . Please check location .as mentioned by Sebastian eiche you can open your original prototype file and check coordinates
Message 4 of 11
S.MANICKAVASAGAM
Thanks lot.
      Drawing frame not in set.
     After frame setting working fine.
      ok.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
Message 5 of 11
Diversteel
Advance Steel 2026
Because i can't change prototype?
Message 6 of 11
D_Waeldele
What's your problem?
Can't you find/open/modify/save the prototype file?
We need more information.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Sorry, this text was automatically translated.
Message 7 of 11
Diversteel
Sorry.
I can´t modify it.
For exemple, i want to replace A3 paper with A2
Message 8 of 11
D_Waeldele
This can be done via the document manager.
(view in My Videos)
Message 9 of 11
Diversteel
I did this other versions.
It doesn´t work in version 2026.
Video attachment
(view in My Videos)
Message 10 of 11
D_Waeldele
Try this out.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-change-p...
Message 11 of 11
Diversteel
Thank you.
But it doesn´t work
