Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
change plate header on bom material list
2 REPLIES 2
javiervega10
200 Views, 2 Replies
Hello dears.
How can I make the bom "material list
summary" divide the plates by thicknesses in inches?
Currently it separates them into metric units,
I understand that it is because I have the "templete units" configured in metric units, but if I configure the units in meters it divides them, for example, the 3/8 and 1/2 plate because they are 9.5 mm and 12.7 mm considers them in a single set, but if I change the units to cms it does separate them, but I don't want the header name them in metric units, I hope have explained myself, I attach some images so that you understand better.
If I change the "template units" to inches, the beam lengths will be modified to inches and I don't want that.
thank you
2 REPLIES 2
AleckGiles
in reply to: javiervega10
Why don't you simply change the length unit to Inches?
Aleck Giles, Structures Consultant, Graitec
LinkedIn
javiervega10
in reply to: AleckGiles
because change the length unit in all the profiles, beams and plates.
I only need the header of the plates per thick, I attach a image
