Change direction of text on symbol section
Hi everybody,
I have a question want to ask. Is there any way to rotate the text of the symbol section? I made i block with the text is 0 degree on rotatte but when i create a section, it's always rotate to 90 degree?
Thank for any help.
HarryHighpants
Have you tried rotating the text in your symbol file by -90 degrees?
i did with all the direction (0,180,90,-90) but it's the same
abs30116
I am not sure what function you are using to creat the symbol, but have you checked to see if the label is set to "Place along object"?  If this is set it will rotate it as needed.  If you uncheck it then it should follow the rotation set for the label.  If it is set to 0 then it should stay that way.  This is just a guess though.
