Dear All,
i would like to find the center of gravity of attached frame .i already tired using the command center of gravity and total weight calculation , but in the model did not reference reference point. please advise
Solved by Sebastian_Eiche. Go to Solution.
Should be there just a small white dot.
Window around the whole assembly and you should find it.
the point is showing..but not seen. try to change the AutoCAD token "ptype" because this point is used for this. I change it to 8% and another point
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
I don't really use centre of gravity very often but I didn't know you could change the type.
Thanks a lot Mr.sebastian.. I have changed the point style and now i can see the reference point.
