Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Can't get multiple parts on a detail when creating drawing
6 REPLIES 6
Eric
955 Views, 6 Replies
Eric
I am trying to create my first drawing in Advance Steel. I have numbered my parts and assemblies and when I use drawing processes I select "all single part page full". It only puts one part per page on the drawing. I am trying to use ANSI D and fill the page up. I have been in the drawing processes manager and checked the filename selector to make sure that close page is set to "on page full". I hope that this is simple, what am I doing wrong?
6 REPLIES 6
alickomay
in reply to: Eric
alickomay
i think to change from single part to mulit part per drawing its all down to the protoype
when making drawing from drawing styles  make shore to selct a prototyppe with "multi" in name
when making drawing with drawing proses (like u are) choce a proces like  "part A1 -MULTI - bom"
Eric
in reply to: alickomay
Eric
Alick, Thank you for responding to my post. Can you attach a screenshot of where to find this? If I go through drawing styles or drawing process manager to get to the prototypes I can't find anything like this. I basically have "all' or "selected" to choose from. When I select "all" it only puts one part on that page.
alickomay
in reply to: Eric
alickomay
made screen cast  be 10 to 30 mins to be redy (ugaly about that time)
mite off been better if i had mic
so at start i make drawing with drawing process
i made single , then delete ,them then make multi
note the name of the proces first one i used had single in name second one had multi in name
then i go to proces maneger and show the setting where u tell it witch prototype to use
it must be a multi prototype if u wont multi part per drawing
(sum of the ones i show are my custom ones , thay wher all made from the "a3 part multi" prototype)
cast is redy Smiley Happy
Eric
Eric
Alick, Thank you for the screencast, but unfortunately I don't see those options for the USA prototypes. I have included a few screenshots to show you what options that I have.
alickomay
in reply to: Eric
alickomay
i think your each is my single
and your pagefull is my multi
go make a drawing with the drawing proces page full and use a large page size
then open drawing a take screen shot of layout details (cee attched pic)
this controls spacing of drawing if it set  to space drawing out to much it may not fit more then one per page
Eric
in reply to: Eric
Eric
Apparently when I modified my ANSI D template I messed something up. I ran drawing processes with ANSI C and it worked just fine.
