Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Can't get beam to show exact in section
4 REPLIES 4
advandes
510 Views, 4 Replies
I am using Advance Steel 2021
I can't get the beams to show up exact in my section views (See attached). I have exhausted my attempts to get this to work and have had to resort to getting help. Your help is very much appreciated. Thanks! I would be glad to provide more information if needed.
AAG
Advance Design
4 REPLIES 4
Sebastian_Eiche
in reply to: advandes
The problem here is: the line for beam is not used maybe. I would suggest, that the beam you would like to see is maybe the main part. Therefore you need to change the line for 'MP beam'.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
advandes
in reply to: Sebastian_Eiche
Thanks Sabastian. Maybe I should have explained more. The beam in question is an existing beam. The model role naming for this beam is "Existing" and I have toggled off all the Behavior settings. I hope this makes sense and may explain the problem.
AAG
Advance Design
Sebastian_Eiche
Then you had to show us the first 16 lines 9f the detail style. Maybe the beam is using another line. You had to know: the detail style works like a pyramid.
Advance start in line 1 and have a look if this model object is the one it need. If not, AS go to line 2 and so on. So it doesn't matter if you change the line 16 of you detail style, if the object is found in line 4 because if the software have a target and found it, it will never search for more.
Example: you beam have the role 'existing' and maybe in your detail style is in line 2 a model object which is based on this role, AS will use this definition and will stop here. It will never have a look in line 16 where the beam is defined, because it already found, what it's looking for.
Sebastian Eiche
advandes
Got it! It was on Line 5 that need to be changed. Thanks Sabastian, I really appreciate you quick response and help.
AAG
Advance Design
