Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Can't add new profile to table editor / management tools
aaronCTEHV
aaronCTEHV
Hi,  I'm having a bit of trouble adding a new section/profile into the table editor in the management tools database.
When I paste the data into the bottom line and rename the standard name a red exclamation mark appears in the left column and won't save? Has the table run out of lines? There is no option for adding another row?
Thanks in advance.
Tomislav.Golubovic
I'm not sure if its related, but I had a training session where the client couldn't add some profiles because they didn't have read+write access to certain folders. Are you an admin of that machine?
aaronCTEHV
Thanks Tom .. I'll try looking into that a bit further.
To be continued.
robertwmerriman2
Hi @aaronCTEHV
To add onto what @Tomislav.Golubovic has said, if you are looking at the permissions for Advance Steel, all the Users / Groups except for CREATOR OWNER need to have Full control and modify ticked as shown below
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
aaronCTEHV
Cheers Rob
