I have multiple projects but most of them look like this, can this tool help me model and create detailed shop drawings of the same?
At the moment I'm using Solidworks which can do the modeling, but it struggles with detailed shop drawings of each component from the Cutlist/BOM.
Hi @avito.lourenco28486 ,
if you are using SolidWorks, look at the Solidsteel parametric:
https://www.klietsch.com/solidworks?m=%2FSolidSteelparametric&lang=en
You can learn to use Advance Steel too, but this would be a new big step for you.
Free - if you have a license only 😎
But should not forget, with Advance Steel you get another world
