Callout View Editing.
seanF2BR4
seanF2BR4
Hello again,
I'm still trying to figure out Advance Steel so forgive me if this is something really easy to edit but i'm currently clueless.  I have created a lovely model and i'm now producing some drawings. A couple of isometric views and some detailed views. I have created a few drawings AS101 - AS105. When i create callout views the text goes outside the bubble. Ideally i'd like to fix this...
I seen something about editing the callouttemplate.dwg but no matter how i justify the text it seems to behave odd in advance steel.
Any guidance on this would be greatly appreciated!
Kindest regards,
Sean
D_Waeldele
this could be due to the template file "CalloutviewTitleTemplate"/"CalloutTemplate". The BL / BR attribute might have false text alignment. Try setting it to top-center.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
J_NortonF9L6Y
You can also delete the label and use your own.
