Caged Ladder rings not showing up in IFC Export
advandes
Advisor Advisor
Message 1 of 12
advandes
Using Advance Steel 2025. I have a finished caged ladder exported to IFC and the Rings are not showing up. Does anyone have any experience with this and know is there is a solution? I've attached the Advance Steel file and a screen capture of the IFC file. Thanks for any help.
AAG
Advance Design
Replies (11)
Message 2 of 12
Flies-Eyes
It is because the Ladder macro uses Polybeams for the cages and the out of the box IFC Exporter can't handle those objects along with Special Parts, Anchors, Curved Beam, Concrete or Timber Beams etc.
Message 3 of 12
vuongbui.nuce
Exporting IFC files in Advance Steel is a bad idea, they use outdated technology for exporting IFC files. I suggest you use Navisworks instead.
Message 4 of 12
Flies-Eyes
I would agree that not all IFC Exporters are equal.    With the right tools, the IFC schema can be an extremely viable method for sharing Advance Steel models to other applications or platforms.  The Link below demonstrates one workflow to take Advance Steel models and associated BIM data to Omniverse.
https://youtu.be/z52ct9HEcws?si=HkuiuZlu6lXpsGWf
Message 5 of 12
mick-CNF
It works OK for me in AS2025.
If this information solves your problem please accept as a solution.
Message 6 of 12
Flies-Eyes
That is very interesting.  Maybe the AdS 2025 IFC Exporter can handle Polybeams.
I haven't tested the 25 version yet.
Message 7 of 12
advandes
If using Navisworks, what is the workflow? Thanks
AAG
Advance Design
Message 8 of 12
advandes
Can you show me your workflow? What software are you using to view the IFC file? Thanks!
AAG
Advance Design
Message 9 of 12
mick-CNF
@Flies-Eyes  Works OK in AS2024 also.
@advandes Standard AS export IFC and BIMvision free viewer.
Message 10 of 12
mick-CNF
Both work with standard export to Navisworks also.
Message 11 of 12
advandes
So, this exporting IFC files has been a request from a client of mine for a number of years now, and I had been instructed to use the "Export IFC MVD EM.11" option. When I use the other option "Export IFC2x3" it works fine. This is not my expertise and I have no idea what the difference is, or why one works and the other doesn't, but I'm sure there will be issues using either option. Thanks everyone for your help!
AAG
Advance Design
Message 12 of 12
Lewk_SGS
From this help article: "The IFC - MVD format is a specific output developed for the U.S. market, by AISC in collaboration with GeorgiaTech, intended to deliver information from steel detailing software to CNC machines, in order to enhance the fabrication process and deliver a standardized format that can be understood by both the software exporting it and the CNC machines."
https://help.autodesk.com/view/ADSTPR/2024/ENU/?guid=GUID-384D2EDA-5BF7-42B9-99D3-A333D59389FB
Lewk_PSB is an old account that is owned by a company I no longer work for.
If this reply answers your question, please "Accept as Solution" - Thanks!
