Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
#C API - Problems creating new Profile
3 REPLIES 3
tiago.pereiraGB2J9
240 Views, 3 Replies
tiago.pereiraGB2J9
I´m trying to create a new profile using C# API, but I´ve found some problems. I want to create a I Type, for example, so, I used:
                ProfileTypeI TypeI1 = new ProfileTypeI();
                TypeI1.H = 100;
                TypeI1.B = 50;
                TypeI1.Tf = 6.8 ;
                TypeI1.Tw = 4.5;
But when I tried to assigned it to my beam, it seems that the software dont recognize the type that I´ve created, like it was missing to save in the database, or something like this.
I think there´s missing some command in my code.
Does anyone know how to solve it?
Thanks!
                TypeI1.H = 100;
                TypeI1.B = 50;
                TypeI1.Tf = 6.8 ;
                TypeI1.Tw = 4.5;
Thanks!
3 REPLIES 3
Sebastian_Eiche
I'm not firm in the API but from my point of view:
Advance Steel is based on profiles from databses, you could not just create an I Type beam with settings as you want.
You had to insert the profiles in the database and then recall it from there.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
tiago.pereiraGB2J9
Thanks @Sebastian_Eiche !
I´ve read about the possibility of inserting the data in the database, but I as have to insert more than 500 new sections of beams, I was thinking in a more automatic way. Besides that, thanks for the reply.
Can I make more two questions?
  • For material type creation, it´s the same? Only writing the information in the database and then recalling it from there?
  • I´ve read that is possible to access the ADVS database in SQL, do you think it´s a good way? I mean, I´ll have the permission to write more data using SQL on the database?
Thanks so much again!
Sebastian_Eiche
For sure you could add it directly in the databases via SQL script
Sebastian Eiche
Sebastian Eiche
