Hi.
When I create the drived drawings the break lines on the steel columns/beams are not showing.
Is there a setup I have missed.
Thanks for any replies.
Shaun.
Hi.
Shaun.
Solved by múinteoir. Go to Solution.
It may be a case that the line clipping is turned off in Management Tools?
Go to Management Tools > Defaults > Drawing Presentation > General > Specifies the default clipping type
