Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
box around part on drawing.
10 REPLIES 10
Message 1 of 11
381 Views, 10 Replies
Just curious what this box (shown in attachment) represents , I couldn't find thread about it online or in the forum.
10 REPLIES 10
Message 2 of 11
johnjmbennett
Could you just check the style used for the drawing, you can access the properties and it should show this.
got a feeling this maybe to do with additional   elements and the assembly selection type from the DS.
John Bennett
Message 3 of 11
bigcarl5000kg
was something deleted in the drawing?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 4 of 11
in reply to: bigcarl5000kg
I did delete one view.
Message 5 of 11
in reply to: johnjmbennett
I right clicked on the part, picked Advance detail properties, under beam - bottom and beam - top I selected either always on or always off instead of auto and the box disappeared
Message 6 of 11
bigcarl5000kg
this box is usually from manually or otherwise deleted objects
Message 7 of 11
I did delete a view I didn't want from the assembly.
Message 8 of 11
bigcarl5000kg
I mean in the drawing 😁
Message 9 of 11
bigcarl5000kg
make a drawing and try to delete something in this ... you will see
Message 10 of 11
johnjmbennett
Ok, so if you delete a view or elements from the view this is update detail box.
to remove this you use the update detail command, you can do this within the drawing file you are in.
labels and dimension ribbon, look for the command on the right side update detail,
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
the grey box should then be removed.   Note this may bring back some dimensions, not sure if the fixed that.
John Bennett
Message 11 of 11
Ok Thanks John, from now on when I see that I will use the update detail command.
