Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
BOM template customization ID column
5 REPLIES 5
372 Views, 5 Replies
Does anyone knows how to add ID column to my Single part list?
5 REPLIES 5
Sebastian_Eiche
I think this Id is not representable in the BOM list. But what work is the Element ID, this is a field content ind the BOM list. To see in the model area, you had to activate a presetting called:
Display beams, plates and joint user ID in the dialog
Then you could see the ID in the Advance property dialog.
The ID which you show us, was necessary in the past, to search for the objects, because you could not double click in the dialog box.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
It doesn't work. Element ID shows some unique number which is useless.
All I want it's numbers 1, 2, 3, 4, 5, 6, ... to know how many different SP parts I have in my project.
Sebastian_Eiche
do you read my post?
The ID which you want to see is not representable.
But you could get your result by using a formula. You could create a field, with a formula and made the following formula:
IQuantitiy/IQuantitiy--> this should always be "1", so in every row, there a field with the content "1" ,you could set this field to not shown:
now should summarize your formula like this:
knowledge
Now you get a summarized result of you formula and this should be the quantitiy of different singleparts.
Your question in the first post didn't show what you want get.
Sebastian Eiche
Thanks for your help
Unfortunately formulas are not available in Advance steel 2016
Sebastian_Eiche
yes that's right
Sebastian Eiche
