BOM on drawind - VBScript
DRAWIND
DRAWIND
Hello, there is a VBScript tab for configuring a BOM, but I'm not sure how to use it. Someone, could I help?
I wanted to concatenate some variables and texts.
%Name + “x” + %Length
to follow the example
Jonathan.Jasinski
So you wouldn't need to use the VB script to do that.  For that label in the editor you can simply type "%Name x %Length" without quotes and it should work.
DRAWIND
Not working, I had already tried this,
I tried again now, it just goes out all white, if you try to concatenate nothing comes out.
I found this link that teaches for external lists.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU...
But for internal BOM drawing does not work.
markhubrich
Bump this 2 year old thread.
I am trying to do a script in a BOM template to make an assy quantity say "ONE" if the qty = 1. If it doesn't = 1 then the field just displays the actual value.
...and fix the kiss export issues.
Sebastian_Eiche
I'm not sure 100% but I think the vbscripts are not working in the bom on drawing. I think this is a problem , because the bom on drawing is something like a block
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Kélcyo
Exactly what I have been looking for now, but this post was in 2017 and so far there has been no solution?
I am beginning to believe that the Autodesk improvement team has not endeavored to help improve ADS
Dias_Antonio
@DRAWIND
I have had this same doubt and posted in this forum... see the link
https://forums.autodesk.com/t5/advance-steel-forum/token-quot-userattribute-quot-disappears-when-set...
It is very similar to your issue
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
