BOM in detailed drawings
bageseabraham
bageseabraham
Is there a way to arrange BOM in “Mark” ascending order?
Please see the attached screen shot. It comes with “Length” descending order.
Abraham
johnjmbennett
Try the listing and sorting,  the first page should show the sort content, set it to the required item, in this case mark number.
John Bennett
bageseabraham
Thanks for the reply.
Sorry I didn't get that. Can you please explain bit more.
That will be much appreciated.
Regards
Abraham.
Sebastian_Eiche
please try to use the sortening button and add the mainpart mark or positionsmark (as you want):
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
bageseabraham
Thanks Sebastian.
I give it a go tomorrow, will let you know.
Cheers
Abraham
chrisengg
First open your BOM Template
Then go to the ribbons in the Output Tab
You will find BOM on drawing
Just above that click on List Sorting and Content
Try a few different lists(Trial and error basis) , you should get the hang of it
Hope that helps
Regards
Francis
bageseabraham
Thanks Francis.
