Hello all.
In the 2019 version when I made an external list using bom editor, with _length_ set to feet and inches, it would show in the list without the minus sign. For example 5' 6 1/2"
Yet in 2021 there now shows a minus sign. For example 5'- 6 1/2"
Does anyone know if it is possible to turn off this minus sign?
We use a software to parse through our lists and this minus sign is messing it up.
Solved by acbsdesign. Go to Solution.
In MT, filter minus, per the screenshot below:
Update defaults after that.
HTH
Happy New year.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
Thank you so much!!!!
Spent over two hours looking for the setting in Bom editor and changing table entries in the databases.
Why would a setting for external list be located under "Drawing Presentation"??? 😰
Anyway I very much appreciate the help!
And you too have a happy new year bud!
