BOM Editor doesn't save
MRizea
MRizea
Hi everyone,
For some reason i can't save the BOM that i've created. I started by copying an existing BOM and then made some editing. The only thing that modification that i can save is the Autodesk Advance logo by replacing it with mine. The rest of the editing just doesn't save. I noticed that if i delete the filed content for the one that are marked with red (q2 picture) then i can keep the settings. If i try to rename them or do something else, it just doesn't save.
Any ideas ?
Thank you,
Marius.
johnjmbennett
in the BOM properties listing on the right side  look to the "Tag" reference,  you need to delete this as well, or it will just revert back to the default text associated with the TAG.
John Bennett
Sebastian_Eiche
if you don't want to do it in every list, this tags are very helpfull, because you could change them onlye one time and it will change it on every list:
like the following thread: click hard on it
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
