I am attempting to produce some grating details. In the BOM I am running into a problem of the description over running the columns allowed and obscuring other columns. Also the length is shown twice? Attached is a sample photo of my problem.
see if this thread helps
Th external BOM allows the use of scripts to edit the data in the data field of a textfield.
Look at
You could use a script to limit the length of a string that is the data of a token. You would have to test how many letters will fit into your text box and then create a script to limit the string's length, like
= ILength.ToString.Substring(0,15). 0 is the start index of the substring, 15 its length....
This way you can avoid overlapping, but of course you may loose information that you need by cutting off a part of the string's end.
iv been triying to remove the sizes after name but cant figure out how
so i kept them and removed the length filed
i edited the grating name in maneger tools it was "redman fisher 41-100-25x5" change to to GR 41-100-25x5
and folled the AleckGiles screencast from muleman1 post above , to lengthen the profile field an shorten the materal an weight
and removed unwonted fields such as area
aded name and date field for sum traceability (use group maneger to add new feilds to group)
if its a single part drawing with nothing els at top u can make the list really wide
