hi,
my last post, got slightly mixed up there, ( was thinking about hole symbols, opps) the actual default colour is coming from the Visible lines Default in the Management tools. so when it is set to default in the drawing style for the bolts presentations line, it is looking at the visible lines colours set in MT.
so as previously mentioned you could change the colour via the DSM:
- Change the Colour under the Drawing Style manager and the change it within the presentation style, but if you do that, i would recommend that you create presentation rule specific to bolts and the colour, as changing the standard one will filter through the system to all presentations that use the "VisiableHiddenSystem" to do this you would use copy, not deep copy, this copies the presentation rule and you can change what is then required inside this rule.
alternatively you could set the bolts to go onto a specific layer in the model and use the colour set in that layer.
to do this i would use two of the MT Default settings relating to layer transfer to the drawing from the model:
model layer for detail objects in over view drawings
colour by layer for visible lines.
result with these settings changes the bolt so the colour is driven by the layer and the layer from the model is also transferred. ( this only applies in overview drawing)
- hope this clarifies my previous post, apologies for confusion.
John Bennett
