Blank Material after Key changed for smlx outputs(Astorbase, AstorProfiles ,AstorControl conflicts)?
SanjoyNath
SanjoyNath
Dear Experts,
Blank Material after Key changed for smlx outputs( Do these Astorbase, AstorProfiles ,AstorControl conflicts)?
We need A992 instead of  ASTM 992  (in the smlx files)
But when we change the data in the    astorbase
How are the dialogs related to the  Materials databases of the AstorBase , and the Astor Profiles?
Suppose we have changed some data in the Material Class and for the Material databases of the AstorBase , then we see the fields are getting blank after adding any beams
Sometimes we check with profilers to see that Advance Steel controls have runtime (Automated query running with where conditions to map the key and the run names which are very confusing and we cannot relate which key impacts which effects on the controls databases
This disturbs in the Addins developments also
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
Sebastian_Eiche
I'm not sure why you change the material class?
If you just need the material, it would be enough to change the material runname.
Another way could be to create this material just with another name.
Sorry but it seems you changed something and don't know what you change.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
SanjoyNath
Dear Respected @Sebastian_Eiche
AstorProfiles mapping change has some direct impacts on the astcontrols
SELECT DISTINCTROW Authors.CompanyText, Authors.CompanyName FROM AstorBase.Authors;
SELECT Authors.CompanyText FROM AstorBase.Authors;
SELECT Authors.CompanyText FROM AstorBase.Authors;SELECT Authors.CompanyText FROM AstorBase.Authors;SELECT Authors.CompanyText FROM AstorBase.Authors;
SELECT ProfileMasterTable.TypeNameText, ProfileMasterTable.TableName FROM ProfileMasterTable;
SELECT ProfileDynamicSubTypes.DynSubType FROM ProfileDynamicSubTypes;
SELECT ProfileDynamicClassDesc.ClassDesc FROM ProfileDynamicClassDesc;
SELECT DISTINCTROW Authors.CompanyText, Authors.CompanyName FROM [AstorBase].Authors;SELECT DISTINCTROW Authors.CompanyText, Authors.CompanyName FROM [AstorBase].Authors;
Sanjoy Nath
