BEVEL RADIUS PLATE CORNER
markhubrich
markhubrich
Does anyone know if it is possible to get the bevel to travel around the radius on this plate? I thought it would work the same way as I have the HSS beveled but it doesn't seem to work.
...and fix the kiss export issues.
acbsdesign
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
s_hannemann
i think i have the same bug. If the corner radial dimension is smaller than the weld preparation  dpeths the bug occurs.
I recommend u change the edges to straihgt If the construction has no dynamic stress. If its dynamic maybe a round plate is the way to go. Maybe change the weld to I-shape if the thickness and WPQR allows it.
Its sad that u have to change the construction because your Computer Aided Software doesnt "Aid" u at all^^
Lewk_PSB
Please see the attached pictures for visual representation of how I made these cuts. The plate shown is 1/2" thick 6" x 6" with 1/2" radiused corners, and the beveled edge is 1/4".
radius bevel corner plate1.pngradius bevel corner plate2.pngradius bevel corner plate3.png
What I usually end up doing for those types of corners is to first create a new plate at the same angle of the bevel cuts in the edges. This is usually a thin plate, in this example it's 1/4" wide. I then bring that plate over the corner and create an element contour to cut the corner of the 1/2" plate. I then use Advance Copy to copy/rotate that element contour around the radius of the corner 6 times or so in 90 degrees. This method usually gets it close enough for our plasma table which can cut beveled edges in plates.
NOTE: Make sure you adjust your UCS appropriately for the polar array to rotate properly 😉
bigcarl5000kg
and here as another rotaded machining (milling):
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
bigcarl5000kg
and here a help fro Forum - see attachment
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
