& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Does anyone know if it is possible to get the bevel to travel around the radius on this plate? I thought it would work the same way as I have the HSS beveled but it doesn't seem to work.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
i think i have the same bug. If the corner radial dimension is smaller than the weld preparation dpeths the bug occurs.
I recommend u change the edges to straihgt If the construction has no dynamic stress. If its dynamic maybe a round plate is the way to go. Maybe change the weld to I-shape if the thickness and WPQR allows it.
Its sad that u have to change the construction because your Computer Aided Software doesnt "Aid" u at all^^
Please see the attached pictures for visual representation of how I made these cuts. The plate shown is 1/2" thick 6" x 6" with 1/2" radiused corners, and the beveled edge is 1/4".
What I usually end up doing for those types of corners is to first create a new plate at the same angle of the bevel cuts in the edges. This is usually a thin plate, in this example it's 1/4" wide. I then bring that plate over the corner and create an element contour to cut the corner of the 1/2" plate. I then use Advance Copy to copy/rotate that element contour around the radius of the corner 6 times or so in 90 degrees. This method usually gets it close enough for our plasma table which can cut beveled edges in plates.
NOTE: Make sure you adjust your UCS appropriately for the polar array to rotate properly 😉
and here as another rotaded machining (milling):
and here a help fro Forum - see attachment
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
