Hi All,
I am trying to do a bevel cut on a cut edge of a circular hollow section. I am able to do the bevel cut on a normal edge using the bevel cut option but it wouldn't work on a cut edge. Can anyone help me with that please?
Regards
Anbu
the bevelcut didn't work in every situation, therefor you could use a polygonal
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Hi Sebastian,
Thanks for your reply. I have already tried the polygonal contour work around. Found that in a old Graitec forum.
https://advantage.graitec.com/en-US/forums/Advance-Steel/68614139-829f-e711-8138-e0071b668071
As you can see in the above picture, the cut is not uniform. I was not sure if that was not properly cut or just a graphical thing.
John Bennett
I created the contour at the middle of the facet and did the polar array. But the cut still doesn't look level.
