Beam to post connection
andrewh540AV3GP
Observer Observer
andrewh540AV3GP
Observer
Observer
Hi All, I am fairly new to advance steel so I'm sorry if this is a simple or dumb question.
is there a way or what is the way to put a top plate on a post for a beam connection ( similar to a base plate connection)
please see below for what I'm trying to achieve without creating a plate then adding holes and placing on the post.
any help on this would be appreciated.
Sebastian_Eiche
use baseplate and the checkbox for "switch beam end":
Another connection could be:
Or you use the endplate connection and place holes. If you use this often, maybe a user connection would be good.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
